Is it possible to configure a 2950 for modem dial-in via console?
bschmi
This is a direct US Robotics modem to 2950 console connection (no control port manager). I've tried following the "dial-in router" guide and the "Connecting a Modem to the Console Port on Catalyst Switches" guide, but haven't had any success. I did find some modem command lines when attempting to config the console, but the switch tells me it's unsupported:
FP03C2903(config-line)#modem dialin
% Line 0 does not support modem control
ANY IDEAS WOULD BE GREATLY APPRECIATED!
6 Replies 6
Bobby Thekkekandam
Try the steps listed here:
http://www.cisco.com/warp/customer/473/2.html
HTH,
Bobby
Please rate if helpful!
Thanks for your assistance, but I had already visited that info and it didn't help. The modem commands listed for the US robotics make my modem freeze, and I'm unable to config line 0 on the switch with dial-in options. The swithc tells me it is unsupported. I don't think it is possible but I was just hoping I may have missed something. Thanks again.
You shouldn't need to configure the modem dial-in paramaters, as the console port does not support RS232 modem control, as an aux port would.
on the switch, you do not need to configure anything at all, although configuring an exec-timeout on the console port is recommended.
For a USR modem:
1) Set dip switches to 3,8 down, all others up
2) Connect modem to PC
3) Run hyperterminal and connect to modem at 9600 baud
4) Send init string: at&fs0=1&c1&h0&d2&r2&b1&m4&k0&n6&w
5) Set dip switches to 1,4,8 down, all others up
6) Connect modem to console port with appropriate cable
Or try these other init strings:
at&f0s0=1&b0&n6&u6&m4&k0&w
AT&FS0=1&C1&D3&B1&K1&M4&W
HTH,
Bobby
Bobby,
Following your instructions to the letter, I was still uanble to access the switch via console. I tried 3 different/new switches, 2 different modems, and 3 different cables (including corss-over).
I really appreciate you following up on this post. Thanks again!
-Brad-
_microsin
If you mean using modem to configure 2950, see link below (language is russian):
http://microsin.ru/html/cisco_content.html#ciscoAndModem
anderson327
Hi dears, you remember how resolved this issue?
I have the same problem.
Please, help me.
