Warning message
Memory for the AS5350
Answered Question
Feb 13th, 2006
Hi.
I am planning in using an AS5350 for VoIP. My question is:
Is there any Table that shows the ammount of memory I have to use for 4 or 8 T1s? If not what is the amount recommended for this cases as SDRAM, and system flash?
Thanks in advance
Juan
Correct Answer by a-vazquez about 11 years 6 months ago
Two sockets hold main memory SDRAM DIMMs. Main memory is used by the CPU to store the operating configuration, routing tables, and queues. The DIMMs can be 128 or 256 MB, and the capacity of the DIMMs in both sockets must match.
For main memory, the total capacity is 512 MB (two, 256 MB DIMMs). One socket holds a shared memory SDRAM DIMM. Shared memory is used to store incoming and outgoing packets. This DIMM can be 64 or 128 MB. For shared memory, the total capacity is 128 MB (one, 128 MB DIMM). This URL should help you:
http://www.cisco.com/en/US/products/hw/univgate/ps505/prod_technical_reference09186a00800a8555.html
Overall Rating: 5 (1 ratings)
Correct Answer
a-vazquez Fri, 02/17/2006 - 07:36
  • Silver, 250 points or more
MAIN CISCO DRAM MEMORY
Maximum Memory: 128mb
Base Memory: 0mb (Non removable)
Upgrade Sockets: 2 (1 bank of 1)
If upgrading to 128 MB (MEM-128M-AS53=), move jumper J3  from position 2-3 to position 1-2, If two flash modules are installed, they must  be of equal size.
CISCO Rx BOOT FLASH MEMORY
Maximum Memory: 16mb
Upgrade Sockets: 1
CISCO  FLASH MEMORY
Maximum Memory: 32mb
Upgrade Sockets: 2 Install Individually
CISCO PACKET MEMORY
Upgrade Sockets: 1
http://simondirect.com/store/index.php?main_page=index&cPath=7_98
