802.1x Vlan Assignment
Feb 13th, 2006
I am planning to implement 802.1x on a 4506 switch. The issue that i have is i have 5 user Departmental vlan on the switch. How can i configure the ACS to assigned vlan for each of my user to their respected departmental vlan? please help
Could you give a little more elaborative explanation about your network topology?. I am not able to assume your network setup from the information you have provided. Or else, just send me your vlan configuration in your switch and your necessity. That will be enough for me to help me.
Roberto Salazar Fri, 02/17/2006 - 13:25
  • Gold, 750 points or more
That can be done, it's called "Using 802.1X with VLAN Assignment". Here is a link on cat4000 on how to configure 802.1X with VLAN assignment:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_25a/conf/dot1x.htm#wp1142124
And here is a link on Using a RADIUS Server to Assign Users to VLANs:
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/b1237ja/i1237sc/s37vlan.htm#wp1038739
I hope this helps.
