02-14-2006 12:24 PM - edited 03-09-2019 01:55 PM
VPN Client Notifications gives me the folloiwing error:
Initializing the connection...
Secure VPN Connection terminated locally by the Client.
Reason 440: Driver Failure.
Connection terminated on: Feb 14, 2006 13:12:19 Duration:
Not connected.
I'm reading material indicating the incompatibility of Windows XP SP2 and Cisco VPN. The work arounds don't seem to be doing much for me.
Any thoughts?
02-14-2006 04:43 PM
do you have the latest VPN client installed? Do you have a personal firewall, which could be interfering with the client?
Also check in your NIC properties, that all services (deterministic network enhancer) are enabled.
Regards, Martin
02-20-2013 01:04 PM
Follow These Instruction. and Update which worked for you
12-21-2020 04:00 AM
