Warning message
CDR Export CDR/CMR Report issue
Feb 14th, 2006
Dear All,
We have CCM 4.1(3)SR2. While using the front end CDR application to export CDR/CMR records we get a system error message and the error code is 10011.Also find attached the screen shot of the CDR Messages.Please let us know what is causing this issue.
Thanks and Regards
Madhu
jbarcena Sun, 02/19/2006 - 13:24
  • Red, 2250 points or more
Symptom:
The feature CDR/CMR is not working properly. When the data is very less, the systems shows an error : 10011: Error: Contact System Administrator. For large data sometimes the CDR/CMR's are downloaded properly while at other times it shows 0 KB downloaded.
Conditions:
4.1(3)
Workaround:
Following would be a workaround to get the CDR Records exported to a DB File (MS SQL, XLS,
TXT etc.) :
1. Goto -> MS SQL Ent. Manager and select the CDR DB. Goto Tables and select
CallDetailRecord.
2. Right click on it and under All Tasks -> Export Data.
3. Under Data Source, it will be your CDR DB on the Ent. SQL Manager. Make sure you've
selected 'Windows Authentication'. Click next.
4. Under Data Destination, you can choose between various options e.g. OLE DB provider,
TXT, Fox Pro Format, csv, dbf, xls etc. Provide the file name and location.
5. Select Copy Tables and views from the source DB. Go next.
6. Select the first option (CallDetailRecord) go next.
7. Click on run immediately and the exported file will contain all the CDR CallDetail
info.
