Warning message
1721 with WIC-1-ADSL
Feb 16th, 2006
Hi to all,
could anyone here previously configured a 1721 w/ wic-1 adsl and it will serve as gateway to client to connect to the internet? do i need to get the PVC # from the ISP? i'ved read some documentations regarding this, but it seems i cant solve the problem.
Please help.
thanks.
mhel
pkhatri Thu, 02/16/2006 - 19:25
  • Purple, 4500 points or more
You certainly do need to get the VPI/VCI from the provider, otherwise you do not have a way to tell the 1721 which PVC to use..
Hope that helps - pls rate the post if it does.
Paresh
mhel Thu, 02/23/2006 - 18:54
I'll try to contact my provider to check what it is.
thanks
thisisshanky Thu, 02/16/2006 - 19:54
mhel,
Most service providers use a particular vpi/vci pair (usually 0/35 or 8/35, some service providers could use a diff. vpi/vci pair). Once you get a VPI/VCI value from service provider, here is a sample config which enables PPPOE on the adsl wic.
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
pvc 0/35 <--- vpi/vci
pppoe-client dial-pool-number 1
interface Dialer1
ip address
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username password
Sankar
PS: please remember to rate all posts!
