Warning message
Upgrade IOS 2501
Feb 17th, 2006
Hi all,
I have problem that my cisco router type 2501 can't support ospf protocol. I want to upgrade the IOS current i used 11.1(6), pls help me....
Thank in Advance
pkhatri Fri, 02/17/2006 - 21:26
  • Purple, 4500 points or more
Firstly, you will need to download a suitable software image from CCO. You will need a CCO login with appropriate privileges to do so. Verify that you have sufficient Flash and DRAM for the image you are downloading.
Then, follow the procedure in the following document in order to actually upgrade the code:
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800941aa.shtml
Hope that helps - pls rate the post if it does.
Paresh
