pkhatri Fri, 02/17/2006 - 22:03
  • Purple, 4500 points or more
The Catalyst Express 500 series switches are intended to be an entry-level switching platform.
I don't believe that there is a hard limit of 250 users when using a network consisting of these switches. However, the idea behind saying that the switch is targeted to a network of up to 250 users is to provide an indication that a network with more than 250 users is likely to require more complex and advanced capabilities than the CE 500 series offers.
So, in a nutshell, your network will not stop operating the moment you add our 251st user..However, if you anticipate such a need, start considering the medium-level switch platforms...
Hope that helps - pls rate the post if it does.
Paresh
ladan.eftetahi Fri, 02/17/2006 - 23:20
thanks pkhatri
I know that we could not config CE500 with CLI command ,so we config these series with network assistant & this software is capable to support up to 250 users, I can't understand this.
could you pls explain me about this software?
thanks
