NAT for Multiple FTP sites
Feb 20th, 2006
I am using NAT overload and static NAT on my router. The router configuration is as follows:
Router(config)#interface fa0/0
Router(config-if)#ip address 192.168.1.254 255.255.255.0
Router(config-if)#no shut
Router(config-if)#ip nat inside
Router(config-if)#interface fa0/1
Router(config-if)#ip address 203.109.120.2 255.255.255.252
Router(config-if)#ip nat outside
Router(config)#ip route 0.0.0.0 0.0.0.0 interface fa0/1
Router(config)#ip nat inside source list 1 interface fa0/1 overlaod
Router(config)#access-list 1 permit 192.168.1.0 0.0.0.255
Router(config)#ip nat inside source static tcp 192.168.1.252 80 interface fa 0/1 80
Router(config)#ip nat inside source static tcp 192.168.1.252 21 interface fa 0/1 21
The ftp site and web server are accessible from the internet.
I have created another FTP site using private IP 192.168.1.250 and default FTP port 21 on FTP server. The site is accessible from within the LAN but not from the internet. Is there any form of static NAT which will allow this. I am out of ideas. Please help
leonvd79 Mon, 02/20/2006 - 05:07
  • Silver, 250 points or more
Use another port for that FTP server (i.e. 2121) or apply for additional public IP addresses.
farhan_p2000 Mon, 02/20/2006 - 05:39
I tried creating another Ftp site using port number 1024 and used the following static NAT command.
ip nat inside source static tcp 192.168.1.252 1024 interface fa 0/1 1024
Again, this site is accessible from within the LAN but not from the internet.
leonvd79 Mon, 02/20/2006 - 05:47
The host for both 21 and 1024. I thought you wanted to use 192.168.1.250 for the secondary FTP server.
"ip nat inside source static tcp 192.168.1.252 1024" uses the same host as "ip nat inside source static tcp 192.168.1.252 21"
Do you have an inbound access-list configured and/or use a firewall that blocks inbound traffic on ports other than 80 and 21 for instance?
farhan_p2000 Mon, 02/20/2006 - 06:02
No there is neither any inbound access-list on the router nor do we have a firewall.
