Warning message
I simply need to change Ip address but I can't
Answered Question
Feb 20th, 2006
I bought a Pix 501, in the configuration, I want to change the default inside interface ip address from 192.1.1.2 to 10.0.2.234, but each time I get an error, "Interface address is not on same subnet as DHCP pool"
So I decide to change the DHCP pool addresses and I get this error:"Address range subnet is not the same as inside interface"
So I can I force the change of those settings?
Correct Answer by lgijssel about 11 years 6 months ago
did this many times. perhaps u are not in config mode when trying to enter your changes?
To begin, your prompt should look like: pixfirewall#
Then enter the following:
conf t
no dhcpd address 192.168.1.2-192.168.1.33 inside
ip address inside 10.0.2.234 255.255.255.0
end
wr mem
This should do the job
Leo
Overall Rating: 5 (1 ratings)
lgijssel Mon, 02/20/2006 - 08:49
  • Red, 2250 points or more
You obviously have a defaulted pix at hand.
In the default config, a dhcp pool is created for the default inside-ip range.
To change it, remove the dhcp-pool first:
no dhcpd enable inside
no dhcpd address 192.168.1.2-192.168.1.254 inside
After that you can change the interface ip on the inside:
ip address inside 192.168.x.x 255.255.255.x
Leo
openheart Mon, 02/20/2006 - 09:00
I tried your suggestion, but same problem.
Again, I need to change the default IP address to another subnet. But the Pix wont let me do it!
Some information about the config I have:
Show ip address:
show IP address
System IP Addresses:
ip address outside 199.243.183.XX 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
Current IP Addresses:
show dhcpd
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
I want to change the ip address(inside) with 10.0.2.234 and disable DHCPD
Correct Answer
lgijssel Mon, 02/20/2006 - 11:15
conf t
end
wr mem
Leo
openheart Mon, 02/20/2006 - 11:27
Thanks it works! I probably did'nt enter the right command to disable dhcpd
