Warning message
CUE Upgrade Issues
Answered Question
Feb 21st, 2006
Hi, I am planning to upgrade my CUE1.1 to version 2.1.2. Referring to the document Installing and Upgrading CUE which is downloaded from CISCO, the method to do it is to run the command "software clean download ftp.." on the router.
However my router (model 2851) do not recognize this command. Can anyone spare any pointers?
Thanks.
Correct Answer by Markus Schneider about 11 years 6 months ago
You need to already have 2.x to be able to use that method. Prior to 2.x the only upgrade option was via the boot helper. Take a look at:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00803c0a1a.shtml
Overall Rating: 4 (2 ratings)
networkkid Wed, 02/22/2006 - 03:58
Thanks for your reply, shanky. This is the same document I used in my first attempt to upgrade CUE. However, I get UNRECOGNIZED PROMPT at the CUE Prompt with the command "software install upgrade".
Any other ways to proceed with the upgrade?
