Warning message
PVC
Feb 21st, 2006
I was working on a 2811router with a T1 connection, my configuration is right, so was the settings at the carrer site(AT&T), I wasn't seeing protocol.
Carrier was able to loop the CSU(in-built), but wasn't receiving any data back from the equipment, all settings and config. has been checked, no luck. Can someone help?
mounir.mohamed Thu, 02/23/2006 - 01:49
  • Gold, 750 points or more
Dear bensonomuke,
Ask your carrier to give u loop on the circute and check if you can receive or not, failed to receive the loop meaning that there is a physical problem.
Best Regards,
Mounir Mohamed
