Warning message
Error Adding new PRI
I've just tried installing a new PRI into my 3745 voice gateway, after configuring the switch-type and line code I tried entering the "pri-group timeslots 1-24" command and I'm receiving this error.
3745(config-controller)#pri-group timeslots 1-24
% Not enough DSP resources available to configure pri-group on
controller T1 0/0
% The remaining dsp resources are enough for 0 time slots.
% For current codec complexity, 6 extra dsp(s) are required to create
this voice
port."
Any ideas would be great.
Chris Deren Wed, 02/22/2006 - 08:33
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
What type of controller hardware are you using?
Did you configure network-clock-participate on the router for clocking, you won't be able to build a PRI group unless you got the clocking.
Chris
jbarcena Wed, 02/22/2006 - 08:42
  • Red, 2250 points or more
You probably have reached the maximum of your available DSP channels and will need to add a new PVDMXX to support the PRI.
