stephtchoko Wed, 02/22/2006 - 23:29
  • Bronze, 100 points or more
I don't know init(io), but i know init (o) which means that cable modem request a config file to CMTS.
Which kind of cmts do you have ?
please, rate this post.
stephtchoko Thu, 02/23/2006 - 02:28
If you cable stay in init(O), you have to verify your config-file.Make sure that after init(d) state (dhcp for getting ip address), the cable modem can communicate with CMTS.
If it is not goog, send me the config file , the dhcp pool of the cable modem and interface cable configuration.
Regards.
