Warning message
Store Long distance Access Code
Feb 22nd, 2006
Is there anyway to store a long distance access code as a speed dial or something else so that whenever user gets promt he can press single button.
Any other workarounds are welcome.
agopala Wed, 02/22/2006 - 13:23
  • Cisco Employee,
what exactly are you trying to do? It appears that if a call comes in with a caller id of 212-555-1212, you want users to be able to just redial, and you want the CCM to introduce a 91 in front of the number. There are some service parameters that you can setup for this to work. You can also use translation rules for this.
Ken Douglas Wed, 02/22/2006 - 14:35
Are you referring to CallManager's Forced Authorization Codes (FACs). My understanding is that if FACs are enabled, you can not store the codes as a speed dial (you have to manually input the code after the two beeps).
