CSS SSL-proxy sends wrong port # embeded in HTTP Host Header
Answered Question
Feb 23rd, 2006
Load balancing works fine and so does SSL offloading. Sniffer traces show that host header sent to the server on TCP 81 has no port number appended to it as required by the HTTP RFC.
In current configuration, verified by a sniffer, TCP 443 hits the content rule and it sent to the SSL-PROXY where it is sent on TCP 81 clear text to the server. The server is listening on TCP 81 and the website reachable. Some scripts were failing so I checked the HTTP HOST Header tag in a sniffer trace and found that although I am sending it to TCP 81, the host header says:
HOST: DEV1.SITE.COM
When according to the RFC and other sniffer traces to working servers (not load balanced) it should show:
HOST: DEV1.SITE.COM:81
Is this a configuration problem, bug or feature? :)
Thanks!
Mike Kelley
[email protected]
---- config attached -----
STGCSS1# sh ver
Version: sg0810002 (08.10.0.02)
!*********************** SSL PROXY LIST ***********************
(IP's changed to protect the innocent!).
ssl-proxy-list STG-SSL-PROXYLIST
ssl-server 20
ssl-server 20 rsakey dev1-key
ssl-server 20 rsacert DEV1.SITE.COM-CERT
ssl-server 20 vip address 100.100.100.203
ssl-server 20 cipher rsa-with-rc4-128-md5 100.100.100.203 81
ssl-server 20 cipher rsa-with-rc4-128-sha 100.100.100.203 81
ssl-server 20 cipher rsa-with-des-cbc-sha 100.100.100.203 81
ssl-server 20 cipher rsa-with-3des-ede-cbc-sha 100.100.100.203 81
ssl-server 20 cipher rsa-export1024-with-des-cbc-sha 100.100.100.203 81
ssl-server 20 cipher rsa-export1024-with-rc4-56-sha 100.100.100.203 81
active
!************************** SERVICE **************************
service STG-SSL-ACCEL
type ssl-accel
keepalive type none
slot 2
add ssl-proxy-list STG-SSL-PROXYLIST
active
!*************************** OWNER ***************************
owner STAGING
content dev1_443
application ssl
add service STG-SSL-ACCEL
protocol tcp
port 443
active
Correct Answer by Gilles Dufour about 11 years 5 months ago
Mike,
this is a known limitation.
Nothing we can do about it right now.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Thu, 02/23/2006 - 08:35
  • Cisco Employee,
Mike,
Gilles.
