TELNET PASSWORD
nhabib Thu, 02/23/2006 - 15:10
  • Red, 2250 points or more
It's either or. It is controled by what you specify when configuring login
For example, if you have the following configured:
line vty 0 4
login
then you will have to use the telnet password.
If you have the following configured:
line vty 0 4
login local
then you will have to use username / password to login.
Richard Burts Mon, 02/27/2006 - 01:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Aksher
If neither of these cases are there the default is to use the telnet password. They only way to use the username and password is to configure login local (or the equivalent configuration using aaa authentication login local).
Rick
