Warning message
Multilink PPP, IP CEF or Both
Answered Question
I will be installing two 2811 routers with four dedicated (point-to-point) T1 connections.
Is it better (faster) to use Multilink PPP, IP CEF, or can I use a combination of both?
Correct Answer by pkhatri about 11 years 5 months ago
Well, CEF is a switching mechanism. IOS supports a number of switch mechanisms:
- process-switching - CPU-intensive
- fast-switching - less CPU-intensive
- CEF-switching - highly optimised.
So you are going to be using one of the above, for sure. It's better to enable CEF and to use that since it performs much better than any of the other methods. In fact, in newer IOSes, it should be enabled by default.
CEF is also required for a number of other things like QoS marking and NBAR. The bottom line is that you have so much to gain and so little to lose by enabling CEF.
Enable it using: 'ip cef'
Hope that helps - pls rate the post if it does.
Paresh
Overall Rating: 3.5 (20 ratings)
pkhatri Thu, 02/23/2006 - 13:16
  • Purple, 4500 points or more
You will need to enable CEF on your router for other reasons, and not just to provide load-sharing.
However, when comparing between using load-sharing via CEF and MLPPP, note the following:
- MLPPP will give you a single interface with a bandwidth of 4*T1. Therefore, you can use up the entire 4*t1 for something like a single data transfer.
- MLPPP is CPU-intensive so you will need to keep an eye on the CPU when you enable it. One option is to use MLPPP but disable fragmentation (which is fine for T1 links)
- with CEF, flows will be load-shared over the 4 links. The disavantage to that is that a single flow will never be able to use more than one T1 since CEF will not allow a flow to use multiple physical links. Therefore, if you try to do somethink like an FTP, you will never get more than T1 through at a time.
Therefore, the recommendation is to go with MLPPP with a word of caution on CPU usage. You will still have to have CEF running on your router but it just won't do load-sharing over these 4 links since you will now have a single multilink virtual interface.
Paresh
Correct Answer
pkhatri Thu, 02/23/2006 - 13:34
Paresh
chad patterson Fri, 01/04/2013 - 10:13
      As I am assuming that you are connecting to an ISP from an edge router, you will want to aggregate your T1's for the fastest, most efficient connection. Which makes pkhatri correct: you will definately want use both. Use MLPPP to aggregate several T1's, but you have to have the ISP configure this on their end too. There are two way with which you can do load-sharing with CEF, per-packet and per-destination, but one is flow-based and neither is nearly as efficient as MLPPP.
     The drawback to per-packet load-sharing is that you will not be able to stream video or use VOiP very effectively (or an UDP based application). The drawback to per-destination is that it is flow based, and therefore will not utilize all lines efficiently. It will favor the line with the best connection, then when that line is full and slow, it will start to use the second best line, and etc. MLPPP on the other hand will evenly and effectively send pacet fragments on all of the lines, and reassemble them at the ISP, so there will be no UDP problems.
     I think a lot of people forget what some of these features are designed for. For instance, CEF is not necessarily optimised for connecting to the ISP from an edge, but it is optimised for routing among managed, interconnected routers.
Joseph W. Doherty Fri, 01/04/2013 - 18:55
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Chad, several statements in your posting caught my attention.  I would appreciate any additional information you might be able to provide for clarification and my education.
"There are two way with which you can do load-sharing with CEF, per-packet and per-destination, but one is flow-based and neither is nearly as efficient as MLPPP. "
As you might note in my other posting, I noted I would expect CEF packet-per-packet to have less overhead then MLPPP, so could you expand on what you mean by ". . . neither is  nearly as efficient as MLPPP."?  Did you have in mind using small fragments so you could transfer a single packet as quickly as possible?
"The drawback to per-destination is that it is flow based, and therefore will not utilize all lines efficiently. It will favor the line with the best connection, then when that line is full and slow, it will start to use the second best line, and etc."
My understanding of CEF, in per-destination mode with multiple links, it just basically round-robined the flows.  Could you provide information or references on CEF selecting "best connections" and switching to "second best" "when that line is full and slow"?
"For instance, CEF is not necessarily optimized for connecting to the ISP from an edge, but it is optimized for routing among managed, interconnected routers."
Could you explain how or when CEF is not optimized for edge to ISP connections?  Are you saying there's something better optimized and/or certain edge to ISP connections for which CEF should be deactivated?
Thanks.
chad patterson Tue, 01/15/2013 - 11:41
     Actually CEF has absolutely nothing to do with MLPPP multilink. CEF is enabled by default and does 'process switching', and should only be turned off if the the interface has a feature enabled that cannot support CEF, which be unlikely in most cases.
     CEF is just a routing trouble, and stores information for hops, i.e.., the best next hop in a route to reach a destination on a given network. If you are connected to the ISP, then the ISP gateway IS YOUR ONLY NEXT HOP, and makes the routing table stored in CEF useless because every singly entry in the table will be "ISP gateway". This assumes you have a simple private local subnet consisting of a mere /24 size. If your private has more than subnet, then CEF will assist in routing to destinations on the local subnet.
     Lastly a link of  MLPPP link of 4 T1's does make that link behave EXACTLY like a single 6Mbps link. It routes packet fragments all up and down those 4 T1 lines as if it were a single line. One can use CEF to aggregate 4 T1's. but there are only two ways to achieve this, and that is through the load-sharing command applied to each interface.
     There are 2 different load-sharing commands, and they both route packets in different ways;
load-sharing per-destination and load-sharing per-packet. If one chooses a per-destination basis, then it is flow based, and will not efficiently utilize all links as ech destination is a single flow. However the drawback to using a per-packet basis is that the packets get fragmented out of order, and UDP based services such as VoIP and streaming media will not work correctly.
     A smart man would choose MLPPP, but you have to set this up with your ISP in advance, as they have to apply MLPPP on their Cisco router well. CEF will not interfere with this and will also not offer any advantage to you (unless you apply load sharing).
     CEF load sharing example:
ip cef
ip cef load-sharing algorithm original
interface WAN1
ip load-sharing per-destination
interface WAN2
Peter Paluch Tue, 01/15/2013 - 15:57
  • Cisco Employee,
Hi Chad,
Please allow me to comment on some of your statements as I happen to have different views.
This is probably a typo. Cisco differentiates very strongly between the process switching and interrupt-context switching. CEF falls into the category of interrupt-context switching. Most definitely, it is not a process switching (although it often is implemented in software as a code that is executed when routing a packet).
I assume that instead of "trouble", you mean "table". However, CEF is not exactly a table. CEF consists of two components, the FIB and the adjacency table. The FIB is a prefix tree that stores the network addresses (prefixes) from the routing table. The tree has been chosen because it provides one of the most effective data structures for retrieval of information. Note that the FIB is initialized using the contents of the routing table, and apart from a handful of system-specific routes, it does not contain anything what routing table also does not contain. Nodes in the FIB tree may contain pointers to the adjacency table, pointing directly to the L2 information relevant for routing packet to or through a particular neighbor. In database terms, the FIB is an index over the adjacency table, with the lookup key being the destination IP address of a packet.
The adjacency table contains frame headers that would be used to deliver packets to or through a particular directly-connected neighbor. This table is constructed using the existing L3/L2 mapping tables like ARPs. For each next hop and a directly connected end host, the router has an entry in its ARP table. Using this information, it can precompute the entire Ethernet header of a frame that would be used to carry packets to or through each next hop router or a host. Again, the adjacency table is not going to hold any other entries apart from existing entries in L3/L2 mapping tables.
I can not agree with the statement that the CEF is useless in the case of just one gateway. Even with just one gateway, the process of routing the packet is more effective using CEF. Just to compare:
  • In process switching, a packet arrives. You take its destination IP, proceed through the routing table in a linear fashion, performing binary ANDs between the destination IP and the netmask in each row of the table, comparing the result of this AND with the network address in the routing table row. Depending on the size of the routing table, tens or hundreds of thousands of ANDings and comparison must be performed before a matching row is found. After finding the first match, you take the IP address of the located next hop from the matching routing table entry. If the routing table entry does not indicate the egress interface, you need to perform a recursive lookup using this next hop address again and again until you find a routing table row that contains also the information about the egress interface. Next, you visit the L3/L2 mapping table associated with the egress interface and lookup the L3-to-L2 mapping of the lastly found next hop. Then you construct the frame header using the located addressing information, encapsulate the packet and send it out. This process repeats with each incoming packet.
  • In CEF switching, a packet arrives. You take its destination IP and start comparing it bit by bit with the values stored in the FIB tree. At most 32 comparisons are necessary. Using the last (deepest) matching tree node that contained a pointer to the adjacency table entry, you immediately locate the template of the prepared frame header and information about the egress interface in the adjacency table. No recursion is necessary as this is resolved during the buildup of CEF structures. No repetitive lookups in L3-to-L2 tables are performed because the results of such lookups have already been processed into the adjacency table.
The CEF switching is thus noticeably superior to the workable but naive process switching.
To be precise, the MLPPP bundle consisting of 4 T1's will be slightly slower than a single 6Mbps link because of additional 4-byte long MLPPP fragmentation header inserted into each fragment travelling over particular physical link in the bundle, consuming some of the bandwidth. It also has to be noted that the fragmentation and reassembly of packets over MLPPP consumes router resources - after a certain number of links in the bundle, your router (its CPU) may become the bottleneck itself instead of the interfaces.
I beg to differ. Even the per-destination load balancing is performed solely by hashing the addressing fields of the packet.
Router#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.0.0.0 is directly connected, FastEthernet0/0
S    192.0.2.0/24 [1/0] via 10.0.0.14
                  [1/0] via 10.0.0.13
                  [1/0] via 10.0.0.12
                  [1/0] via 10.0.0.11
Router#show ip cef exact-route 1.1.1.1 192.0.2.1
1.1.1.1         -> 192.0.2.1      : FastEthernet0/0 (next hop 10.0.0.14)
Router#show ip cef exact-route 1.1.1.1 192.0.2.2
1.1.1.1         -> 192.0.2.2      : FastEthernet0/0 (next hop 10.0.0.11)
Router#show ip cef exact-route 1.1.1.1 192.0.2.3
1.1.1.1         -> 192.0.2.3      : FastEthernet0/0 (next hop 10.0.0.12)
Router#show ip cef exact-route 1.1.1.1 192.0.2.4
1.1.1.1         -> 192.0.2.4      : FastEthernet0/0 (next hop 10.0.0.12)
Router#show ip cef exact-route 1.1.1.1 192.0.2.5
1.1.1.1         -> 192.0.2.5      : FastEthernet0/0 (next hop 10.0.0.12)
Router#show ip cef exact-route 1.1.1.1 192.0.2.6
1.1.1.1         -> 192.0.2.6      : FastEthernet0/0 (next hop 10.0.0.14)
Router#show ip cef exact-route 1.1.1.1 192.0.2.7
1.1.1.1         -> 192.0.2.7      : FastEthernet0/0 (next hop 10.0.0.12)
Router#show ip cef exact-route 1.1.1.1 192.0.2.8
1.1.1.1         -> 192.0.2.8      : FastEthernet0/0 (next hop 10.0.0.12)
Router#show ip cef exact-route 1.1.1.2 192.0.2.1
1.1.1.2         -> 192.0.2.1      : FastEthernet0/0 (next hop 10.0.0.13)
Router#show ip cef exact-route 1.1.1.3 192.0.2.1
1.1.1.3         -> 192.0.2.1      : FastEthernet0/0 (next hop 10.0.0.13)
Router#show ip cef exact-route 1.1.1.4 192.0.2.1
1.1.1.4         -> 192.0.2.1      : FastEthernet0/0 (next hop 10.0.0.12)
Note that the changing combination of source/destination IP results in a different hashing value, thus into a different egress interface and next hop. However, repeating the same command several times will always produce the same path:
Router#
I believe you are inferring this based on a wrong premise. CEF was optimized to provide rapid lookup of frame rewrite information and egress interface, something that you are always interested in, regardless of how many neighbors you have - either a single ISP or dozens of neighboring routers.
Best regards,
Peter
chad patterson Wed, 01/16/2013 - 15:05
     OK, you called me out on that one. My statement on that was just plain wrong. CEF isn't process switching. I meant that basically performs the same thing, but that's not how it came out at all. So i admit that was a bad and misinformative statement.
     However as far as the rest of your post is concerned, I'd say it's a bit off topic and misleading. I was responding to original poster's question as to whether he should use MLPPP or CEF to aggregate 4 T1's. Don't believe me? Then please refer to the original post. Now whatever it was that I posted was in relation to that topic: MLPPP vs CEF. And if you think they do the same thing, you are wrong. Have you tried to apply them in the real world? I aggregate T1's and ADSL lines all the time.
     Now with MLPPP you get one interface. Packets gets fragmented and reordered correctly. How is this significant you ask? Well that means you can stream movies and use VoIP services on that network. There may be a slight framing cost, but it is insignificant. When I run a speed test of a MLPPP 8 of bonded T1's, I get a 12Mbps download speed.
     Let's consider using CEF on 8 T1 lines shall we? First of all, with CEF, you don't get true aggregation: you get 'load-sharing'. You have to specify this on the interface level by the way. However there are two forms of load-sharing that CEF can use; per-destination and per-address. Their variance is significant.
     When you use the per-destination form of load sharing, your packets are routed by source/destination flows. Meaning that when you open a service on the intertnet, you will use only one T1 line to transport all of your packets: of course you will use all 8 T1 lines at the same time for seperate services, they just will not be in sync with each other. You can use streaming media and VoIP services with this setup. But when you run a speed test, you will never surpass 1.5Mbps. That does not even come close to 12Mbps!
     When you use the per-packet form of load sharing, your packets are sent down all 8 of the T1 lines, but since they use different routes, they are not ordered. You CANNOT use streaming media and VoIP services with this setup. When you run a speed test, you will not even come close to 12Mbps.
     You can also use route maps in conjuction with CEF, but guess what; you will still not surpass 1.5Mbps! Have you found a way to surpass these limitations? If so do tell!
Peter Paluch Wed, 01/16/2013 - 15:32
  • Cisco Employee,
Hi Chad,
Thanks for responding.
Yes, I admit I am off-topic with respect to the topic of the original question - because I reacted to some claims about CEF you made that I found myself in disagreement with. I have openly stated I am going to react to some of your claims, not to the claims of the OP, and I quoted each of your statements I've presented a counterview to - making my response on-topic with your post. It is normal to branch off a discussion in an open threaded forum. I do not think, though, that I was misleading, i.e. leading to wrong conclusions, in my response. From my perspective, I felt some of your statements about CEF were not entirely correct so I reacted.
Best regards,
Peter
chad patterson Wed, 01/16/2013 - 15:20
     Peter, I have to call you out on this. You cannot get around the fact the CEF uses a database (whatever name you want to give it, it is basically a database (and by the way a table is a database)) to find the best next-hop for a packet. This is the main function of CEF.
Taken from http://www.cisco.com/en/US/docs/ios/12_1/switch/configuration/guide/xcdcef.html#wp1000937
The two main components of CEF are as follows:
  • Forwarding information base (FIB)— CEF uses an FIB to make IP destination prefix-based switching decisions. The FIB is conceptually similar to a routing table or information base. It maintains a mirror image of the forwarding information contained in the IP routing table. When routing or topology changes occur in the network, the IP routing table is updated, and those changes are reflected in the FIB. The FIB maintains next-hop address information based on the information in the IP routing table. In the context of CEF-based MLS, both the Layer 3 engine and the hardware-switching components maintain an FIB.
  • Adjacency tables—Network nodes in the network are said to be adjacent if they can reach each other with a single hop across a link layer. In addition to the FIB, CEF uses adjacency tables to store Layer 2 addressing information. The adjacency table maintains Layer 2 addresses for all FIB entries. As with the FIB, in the context of CEF-based MLS, both the Layer 3 engine and the hardware-switching components maintain an adjacency table.
     Please refer to this documentation to see how CEF uses ADJACENCY TABLES to store MAC addresses, in conjuction with a FIB to find NEXT-HOP ADDRESS INFORMATION.
     Now Peter, I don't know what kind of relationship you have with your ISP, but if they allow to skip their router (which is the thing that is ADJACENT to your edge router) and connect directly to 8.8.8.8 (Google) as a next-hop, then can you please give me their phone number?!
Peter Paluch Wed, 01/16/2013 - 15:51
  • Cisco Employee,
Hi Chad,
Am I saying anything different? The result of routing a packet is encapsulating it into a properly addressed frame and sending it out the appropriate interface towards the next hop which is identified by the L2 addressing information in the frame. That is why I wrote that "CEF was optimized to provide rapid lookup of frame rewrite information and egress interface". Taken from
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_white_paper09186a00800a62d9.shtml#express
"Cisco Express Forwarding, also uses a 256 way data structure to store forwarding and MAC header rewrite information"
The FIB does not need to store next-hop address information because it does not need it to perform packet routing. I am openly stating that the documentation is not precise on this point. The next hop address is just the first step in locating the frame header rewrite information, and is discarded afterwards. During the construction of FIB and adjacency table, this second step of translating next hop IP addresses into L2 addresses has been done so there is no use for next hop IP addresses in the FIB anymore. FIB stores the destination networks only. From the same document indicated above:
Cisco Express Forwarding uses a trie, which means the actual information being       searched for is not in the data structure; instead, the data is stored in a       separate data structure, and the trie simply points to it. In other words,       rather than storing the outbound interface and MAC header rewrite within the       tree itself, Cisco Express Forwarding stores this information in a separate       data structure called the adjacency table.
Best regards,
Peter
chad patterson Wed, 01/16/2013 - 16:03
     Peter you are saying something different. In the context of this discussion, you have been arguing that CEF is optimized for routing packets between an edge router and an ISP. But it is not; it is optimised for processing packets. OK, so CEF knows where the best next-hop is faster than process-switching, great. It still only has one hop to choose from! Therefore it is not optimised for routing form an edge router to an ISP, like say MLPPP is. It also cannot choose efficiently between 8 different equal-cost lines that are only one hop away from the ISP, because they are only one hop away (but CEF will make that decision faster, LOL).
Peter Paluch Wed, 01/16/2013 - 16:22
  • Cisco Employee,
Chad,
I believe I have written that the CEF is optimized for rapid lookup of information necessary to perform packet routing, and that it is irrelevant for CEF's performance how many hops it can choose from.
Please note that by saying CEF, I am not talking about load-sharing whatsoever. When I talk CEF, I talk about performing the basic routing using the FIB/ADJ. I am not talking about "spreading" the traffic through several links. That is an added value to CEF but it is not its defining property. This may be the point where we diverge in our understanding.
I do not believe that putting CEF and MLPPP into this kind of relation - "CEF is not optimised for routing from an edge router like MLPPP is" - is appropriate. In doing this, you are trying to compare and contrast two totally different things. CEF is a realization of the routing function. MLPPP is a link layer technology with no relation to routing whatsoever. Even with MLPPP running on edge router, you need routing as the internal LAN interfaces of the edge router are on different networks. Whether CEF's load balancing (or sharing) mechanisms can replace MLPPP - no, I don't think they can. They can do load balancing but they do it differently, not equivalently to MLPPP.
Best regards,
Peter
chad patterson Thu, 01/17/2013 - 08:14
Peter,
     please keep in mind that this discussion is not about the virtues of CEF. I do see however that you really enjoy discussing the virtues of CEF, so I suggest that you start a new discussion based on the virtues of CEF. If you will you refer to the original post, which I have been trying to guide you to do for some time now, you will see that the original poster did ask IF HE SHOULD USE CEF OR MLPPP TO AGGREGATE 4 T1 LINES!
     So what the heck do you mean when you say,
     You should try to realize that in the context of this discussion, YOU CAN USE EITHER CEF OR MLPPP to accomplish what the original poster is trying to accomplish. If you are unaware of this fact, then why are you muddling this discussion with your ramblings? Please keep your postings in the context of the discussion, and quit being argumentative and try to understand that other people may have the same question, and they will refer to this thread for an answer.
Best regards
Peter Paluch Thu, 01/17/2013 - 09:41
  • Cisco Employee,
Hello Chad,
True, this discussion is not about the virtues of CEF, but it touches CEF. And once the CEF is mentioned, it has to be discussed in exact terms, and if dubious information about it is posted in the process, it has to be corrected. This goes for every topic.
If you will you refer to the original post...
If you refer to the original post you will see that it has been posted on February 23rd 2006. Your answer comes 7 years late. I am surprised you are defending the relevancy and "on-topic-ness" of your answers so ardently considering they will most probably pass unnoticed after such a time, as the OP must have had his issue resolved sooner. Your posts not only came late, they also contained or suggested incorrect understanding of some aspects of CEF. If I, in my answers, provided an additional context to how CEF works (which you called an off-topic content), it was intentional to properly explain why I considered some of the facts in your answers as being questionable. I could as well just say "this is wrong, that is wrong" without explaining why it is wrong but that would help nobody.
... which I have been trying to  guide you to do for some time now, you will see that the original poster  did ask IF HE SHOULD USE CEF OR MLPPP TO AGGREGATE 4 T1 LINES!
I am not arguing that. But you posted answers that contained questionable or misleading statements about a particular technology and I reacted to those. If such imprecisions occur in answers, even though they tackle an off-topic theme, I am and will be pointing them out and setting them straight. An imprecision, or an outright incorrect statement in a post can not be just summarily dismissed with a convenient comment that "it is off topic, anyway". Participants reading these answers absorb them in their entirety so our mutual striving should be to post entirely correct answers. Many imprecisions or misunderstandings occur from saying tiny incorrect things here and there, and they tend to accumulate. Trust me on this, I work in education and I am acutely aware of the damage caused by these "slight, off-topic imperfections".
Chad, and one more thing - in my over 5,500 posts on CSC, I have never allowed myself to call anyone argumentative, trite or rambling (you may check using the Search function). Having such strong judgements about the people you debate with, without knowing anything about them and the knowledge/experience they speak from, is utterly presumptuous and undignified. Considering you are a freshman here on CSC and have yet to build up your reputation, you behave in an overbearing, imposing way, not really trying to seek a mutual understanding and a common ground with other people but at most, trying to force your own views upon them, and when it fails, dismiss them offendingly. The only reputation you are building so far is a negative one. Please, try to change your attitude.
Best regards,
Peter
Joseph W. Doherty Thu, 01/17/2013 - 20:27
Disclaimer
Posting
I'm sorry, where did I write CEF does have something to do with MLPPP?  I contrasted how the two can load share across multiple links, but didn't directly relate them.  Although I didn't touch upon their relationship, there is one, as CEF can use a multilink interface as its egress interface.
It's true CEF is generally the default in current IOS versions, but I believe I recall when the feature was first introduced (12.0?), it had to be explicitly enabled.
Cisco doesn't consider CEF "process switching", they consider it "fast path" or "interrupt switching".
As Peter has already touched upon CEF, I refer readers to those posts.
If you mean MLPPP will logically behave like a single link, you're correct.  If you also mean link will perform exactly as a physical link, no it will not.  Simple example, send one packet, w/o MLPPP fragmentation and it will take over 4x longer to transmit.  This because the single packet is serialized across a 1.5 Mbps physical link rather than a 6 Mbps physical link.  If if there are exactly 4 equal size packets (or 4 MLPPP fragments), MLPPP introduces, I believe, a little more protocol overhead on the links and adds some additional processing latency.  The 6 Mbps link will deliver packets just a little sooner and, if there's less protocol overhead, at a very slightly higher transfer rate.
If you think such minor performance differences are insignificant, often they are but sometimes they are not.
chad patterson Mon, 02/25/2013 - 16:26
     OK. My bad. My apologies to all. I have reread this conversation and have come to a new understanding of our miscommunications. I had assumed we were all on the same page, which I am prone to do sometimes. But it is my fault that we were not, because I did not articulate clearly.
     Whenever I mentioned CEF, in the context of using it with 4 T1 lines, I assumed it was understood that I was talking about 'CEF load sharing'. That is the only option involving CEF in this scenario. Yes I do agree that CEF is a good thing and it is better than 'naive proccess switching' (good term by the way). But I assumed that we all understood that 'naive process switching' is not even an option when it comes to load balancing 4 T1 lines.
     So I tried to guide the conversation towards CEF vs MLPP because all of my CEF statements were made in that context, and not in the context of CEF vs NAIVE PROCESS SWITCHING. So I issue a friendly challenge to all who were arguing with me: I will give you all the kudos if you can post a configuration, using only CEF and not MLPPP, that load balances 4 T1's. Never mind whether or not it ends up being inferior to MLPPP, I just want to see if any of you can even do it successfully.
Joseph W. Doherty Mon, 02/25/2013 - 18:01
Disclaimer
Posting
!router 1
conf t
in s0/0/0
ip add 192.168.0.1 255.255.255.252
no shut
exit
in s0/1/0
ip add 192.168.1.1 255.255.255.252
no shut
exit
in s0/2/0
ip add 192.168.2.1 255.255.255.252
no shut
exit
in s0/3/0
ip add 192.168.3.1 255.255.255.252
no shut
exit
router os 1
network 192.168.0.0 0.0.255.255 area 0
end
!router 2
conf t
in s0/0/0
ip add 192.168.0.2 255.255.255.252
no shut
exit
in s0/1/0
ip add 192.168.1.2 255.255.255.252
no shut
exit
in s0/2/0
ip add 192.168.2.2 255.255.255.252
no shut
exit
in s0/3/0
ip add 192.168.3.2 255.255.255.252
no shut
exit
router os 1
end
If you enable "regular" CEF it will hash flows across the serial links.  If you enable the packet-by-packet option, it will round robin a flow's packets across the links.  (Note the above assumes ECMP, allowing 4 routes.)
chad patterson Wed, 03/13/2013 - 14:43
Again it comes down to IP CEF vs. MLPPP, and NOT  OSPF vs. MLPPP.
You're assuming that the routers will be using the T1's to talk to each other. I am assuming he will be putting 4 T1's on each router, that each router will be internet facing, the routers will not be talking to each other, and therefore would render OSPF completley useless. Now show me the CEF scenario.
Joseph W. Doherty Wed, 03/13/2013 - 17:53
Disclaimer
Posting
No, I'm not assuming that, as the OP states:
On the other hand,
OP doesn't mention Internet, so yes, I agree, you're assuming.  Also "dedicated (point-to-point T1 connections", at least to me, implies leased lines between two of the OP's routers, i.e. those routers will be talking to each other and have nothing, whatsoever, to do with Internet facing.  So, OSPF might not be completely useless as you also assume.
But, even using your assumption, that we're working with Internet facing links, IP CEF works with more than OSPF.  For example, you could use it with BGP or with, I believe, static routes too.
Perhaps for Internet statics:
!router 1 (client side)
conf t
in s0/0/0
no shut
exit
in s0/1/0
no shut
exit
in s0/2/0
no shut
exit
in s0/3/0
no shut
exit
ip route 0.0.0.0 0.0.0.0 192.168.0.2
ip route 0.0.0.0 0.0.0.0 192.168.1.2
ip route 0.0.0.0 0.0.0.0 192.168.2.2
ip route 0.0.0.0 0.0.0.0 192.168.3.2
end
!router 2 (ISP side)
conf t
in s0/0/0
no shut
exit
in s0/1/0
no shut
exit
in s0/2/0
no shut
exit
in s0/3/0
no shut
exit
!where a.b.c.d is some public /24
ip route a.b.c.d 0.0.0.255 192.168.0.1
ip route a.b.c.d 0.0.0.255 192.168.1.1
ip route a.b.c.d 0.0.0.255 192.168.2.1
ip route a.b.c.d 0.0.0.255 192.168.3.1
end
chad patterson Thu, 03/14/2013 - 13:55
Josep,
Do you get this a lot on ypur routers (just wondering)?
#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Joseph W. Doherty Fri, 03/15/2013 - 09:35
Disclaimer
Posting
I don't routinely have a need to ping external IPs, but just tried 8.8.8.8:
#ping 8.8.8.8 re 1000
Sending 1000, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 8/15/42 ms
Of course, I'm not using MLPPP
chad patterson Fri, 03/15/2013 - 10:35
Of course that's not tested on a router that has more than one WAN facing interface, using only CEF. I'm trying to point out that you need to use route-maps to acheive that result. With MLPPP, of course you need not configure route maps.
Joseph W. Doherty Fri, 03/15/2013 - 12:16
Disclaimer
Posting
Oh, sorry, I didn't realize you were looking for a WAN facing IP CEF test.
Unfortunately, in my current position, I don't support any multi-p2p to the Internet.  My "WAN" is generally Ethernet, either dedicated/private fiber or on our OTN, usually gig, some 10g.  We may have a few multi-p2p between internal pairs, but it's rather rare as either we're using bundled links (Etherchannel) or the multi-p2p goes to different devices on other side (which may or may not be ECMP).
In any case, since CEF came out, don't recall ever seeing a ping issue like you describe on any logical ECMP.
Unsure why you belive you need to use route-maps with CEF.
Perhaps you should post your (complete) config that encounters the ping issue you describe.
chad patterson Fri, 03/15/2013 - 14:54
  We discussed this in another thread, and when I said something like, "CEF is not best for WAN", well this scenario is what I was refering to. OK, it's fine you have multilple parrallel links, but still not as good as MLPPP.
However in the scenario we are discussing now, Yiou simply cannot do it with CEF alone.How could you? CEF uses Layer2 info to decide what the best next hop is, and with a routing protocol like OSPF to advertise all the hops in a route, CEF will not get you end to end. In a WAN facing situation, CEF only knows that the next best hopis the ISPs router, and nothing more.  In short, CEF will get you to next best-hop. That means all of the routers in the chain have to share route info, which is what OSPF does, and why CEF cannot route over a WAN facing link.
Now I realize that MLPPP also resides at layer 2, but you have to coordinate it with your ISP and so it works perfectly. Thats why you get 6 mbps with 4 T1's using MLPPP. You simply cannot do this with CEF.
Joseph W. Doherty Fri, 03/15/2013 - 20:36
Disclaimer
Posting
Chad as Peter would say "I beg to differ" with much of your last post's contents as it appears to have many misconceptions about CEF.
chad patterson Mon, 03/18/2013 - 14:44
Can you please provide a working config consisting of multiple (2 or more) WAN facing interfaces, each with their own public IP addresses, and routing out of those interfaces with CEF? I'd like to see it work in the way that you insist it does. (obviously you shan't be able to use OSPF or BGP or such)
Joseph W. Doherty Mon, 03/18/2013 - 19:51
Disclaimer
Posting
As I've already written, I don't currently support any multi-link, on the Internet, with public IPs.
As I've also already written, I might find a current example with private IPs, but as I also noted, these in my current environment would be rare somewhat excepting ECMP.
Do you have such a device I could configure for you?  Or review its config?
Joseph W. Doherty Tue, 03/19/2013 - 05:19
Chad, I'm wondering, are you thinking of a L2 MLPPP or L3 MLPPP?
Joseph W. Doherty Fri, 01/04/2013 - 18:32
Disclaimer
Posting
As the others have posted, especially Paresh, you almost always want CEF enabled.  About the only valid reason for turning it off would be if you're debugging an issue that might be caused by CEF.
Normally you would also opt for MLPPP as its huge advantage is to provide the aggregate of all your links; even to a single flow.  (As also noted by Paresh.)  Basically your 4 T1s should behave much like (but not exactly like) a single 6 Mbps link.
The disadvantage of MLPPP it does increase overhead on the router to manage it and consumes some of your link bandwidth.  From my experience using MLPPP on 2811, on 4 T1s, the overhead is usually minimal as long as you don't enable MLPPP fragmentation support (once again also noted by Paresh, but I think he didn't mentioned the slight usage of your link bandwidth .)
Fragmentation can "slice and dice" individual packets across your multiple links, making your 4 T1s even more like a single 6 Mbps, but increases the MLPPP processing overhead.
One area where I differ with Paresh, he's correct CEF normally directs the same flow to just one link, but some CEF implementations also offer packet-by-packet load sharing.  This would send packets somewhat similar to MLPPP, w/o fragmentation, and likely with less overhead.  However, it would also likely disrupt a flow's packet sequence, which can create a bunch of performance issues! (I highly, highly recommend you don't pursue this, especially across four links unless you know all your traffic is packet ordering insensitive!)  MLPPP guarantees the receiving router will restore a flow's packet sequence before it forwards.
Lastly, MLPPP, since it treats your 4 physical links as one logical link can reduce (very slightly) resource usage for maintaining routing.  I.e. one p2p link to logically handle vs. four of them.
