Warning message
spanning tree
Feb 24th, 2006
Can anyone tell me how I would make a certain switch on my network the root bridge, and how would I make sure that the next switch to it blocks the loop, is it always the switch next in line to the root bridge that blocks the loop ?
Overall Rating: 3 (1 ratings)
dwyerr Fri, 02/24/2006 - 03:30
It is a bit dependant on the platform you are running but generally I would use the following.
spanning-tree vlan root primary
It is also considered best practice to manually set the secondary root as well.
spanning-tree vlan root secondary
The above commands are setting the priority for you which is why I feel it's the best/cleanest method. This, however, can also be done manually.
:root
spanning-tree vlan priority 8192
:sec root
spanning-tree vlan priority 16384
The thing to remember is the switch with the higher priority ,lower value, becomes root. The switch with the second highest priority becomes secondary.
To answer your other question , all ports on the root bridge will be in forward state. All other switches in the topology will have only one root port in the forward state, baring any type of load balancing methods, creating a tree leading back to the root.
-Rob
