How to enable RSTP
Feb 24th, 2006
Can someone please explain how to enable RSTP in the switch (Let's say in 2950 switch).
Or do you have RSTP running in now-a-days switches?
Thanks in advance!
Chris.
mail4ramsay Sat, 03/24/2012 - 05:22
Cisco switches by default run PVST+ (Per VLAN Spanning Tree+) which is compatible with 802.1d STP.  Most newer switches support PVST+, Rapid-PVST+ & MST.  With IOS-based switches you can check what version you are running with the command 'show spanning-tree summary':
switch#show spanning-tree summary
Switch is in rapid-pvst mode
<<<< Output Omitted >>>
switch#
To change the STP mode use the global configuration command 'spanning-tree mode XXX':
switch(config)#spanning-tree mode ?
  mst         Multiple spanning tree mode
  pvst        Per-Vlan spanning tree mode
  rapid-pvst  Per-Vlan rapid spanning tree mode
Switch(config)#spanning-tree mode rapid-pvst
