SSL VPN connection to ASA
shaun.robin
Has anyone had any problems downloading files being served off of a win2k3 (IIS 6.0) web server through an SSL VPN tunnel? I have an asa5520 running 7.1 code. I am able to view https pages but am not able to download files from these pages. The download seems to complete but looking at the file size on the web server and that of the downloaded file reveals that only a very small percentage of the file has been downloaded. This problem only seems to happen with https pages from an IIS 6.0 web server(I have also tested http against the IIS 6.0 web server and http/https against an IIS 5.1 and had no problems). I have also tried these same tests from an internal address (not through the ASA) and had no problem.
Any thoughts would be much appreciated.
mpalardy
Level 3
Level 3
Any errors reported on ASA interfaces?
Check ip/mask/speed/duplex either on ASA and server.
Yeah I thought of that as well but no...no errors. The thing that I find confusing is that it's only https gets that I'm having the problem with. As I mentioned, http worked ok.
Did you try disabling webvpn caching?
