Warning message
Using 1300 with Yagi
Feb 24th, 2006
hi to all
I am stuck in a problem, we have a aironet 1300 series with yagi antenna we get the response but it was very hi i.e 1500 msec
Can any body tell me wat can i do to decrease the response time. as the distance to main branch is 5Km.
Please help me regarding this issue.
scottmac Sat, 02/25/2006 - 07:30
  • Green, 3000 points or more
It's likely to be an interference issue. The interference is (probably) causing a high nuber of re-transmits.
Try lowering your RTS threshold.
Try other channels.
Verify that your antennas are optimally aimed.
If none of the above works, you may need to switch to a parabolic (dish) antenna(s) - they have a tighter pattern for transmit and receive and perhaps you can exclude or reduce the interfering signal.
Good Luck
Scott
