Warning message
unity express redirected number
Feb 27th, 2006
Sometimes our receptionist leaves and wants to forward the reception phone to someone else in the office. However, when she does so and the other person does not answer the phone it goes to her voicemail and not receptions. Is there a way to send it to the original called number or redirected-number (receptions in this case) voicemail?
I am running CUE 2.1
Overall Rating: 5 (1 ratings)
Markus Schneider Tue, 02/28/2006 - 07:37
  • Cisco Employee,
CUE *only* has the ability to use the last redirected number (LRN), not the original called number (OCN). In CUE 2.3, I believe, support will be added for OCN; however there may also be some dependencies on the switch (i.e. CalManager Express/Callmanager version).
debhendon Mon, 07/03/2006 - 04:22
I have CUE 2.3.1 and need this capability as well. Are you aware if redirecting to the OCN is available now?
Rob Huffman Mon, 07/03/2006 - 06:30
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Deborah,
This feature is now available in CUE 2.3 have a look;
Mailbox selection
This configurable option specifies the mailbox to be used in case of call forward. SIP phones are not supported.
From this doc;
Cisco Unity Express
Release Notes for Cisco Unity Express 2.3
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_release_note09186a0080679b50.html
Mailbox selection: Mailbox in which an incoming voice message is stored. The options are original called number (OCN) or the last redirected number (LRD). LRD is the default option.
For example, suppose caller A calls user B's extension, which forwards the call to user C, who does not answer the phone. The call goes to voice mail. User B's extension is the OCN and user C's extension is the LRD. If the system is configured with the OCN option, the system stores the message in user B's mailbox. If the system is configured with the LRD option, the system stores the message in user C's mailbox.
From this doc;
Cisco Unity Express 2.3 GUI Administrator Guide
http://www.cisco.com/univercd/cc/td/doc/product/voice/unityexp/rel2_3/cue_cli/ch3sys.htm#wp1075610
Hope this helps!
Rob
Please remember to rate helpful posts............
