Warning message
Problems with access-list's
Hello Cisco Moderator.
Maybe you can help me, i have problems configuring a pix with three ethernet interface.
eth0 is the outside.
eth1 is my LAN of PC's.
eth2 is my DMZ.
In the DMZ i have a branch incoming trough a router.
I can go from outside to dmz with global, static nat and access-list.
I can go from inside to dmz with global and nat
I can go from branch to dmz because the router is in the same dmz.
I can´t go from inside to branch, when i put access list rules my dmz services go down.
What can i do, please help me.
Patrick Iseli Tue, 02/28/2006 - 07:39
  • Gold, 750 points or more
Could you please post your access-list for the DMZ and note which IP Blocks is on which interface !
Remove Public IPs and replace the first 3 octects with an X.
example: x.x.x.4
sincerely
Patrick
