Warning message
Main Number plays transfer Message
Feb 28th, 2006
We have a customer who when you dial their main number, it plays a "please wait while I transfer your call" message before it reaches the DN. The main number itself is simply associated with a line on a phone and that's it. There's nothing in Unity. The calls are coming in through an FXO port across the WAN to CCM and then back to the phone (everything is MGCP). It's really weird. Any ideas?
Alan
jbarcena Tue, 02/28/2006 - 12:04
  • Red, 2250 points or more
Can you please upload the CCM detailed trace of the call? This will help to see what is happening to the call.
Tommer Catlin Tue, 02/28/2006 - 12:06
  • Green, 3000 points or more
Is Unity involved? Because if the main number Open Greeting or something of that nature got changed in Unity, someone could have set it to automatically transfer to an ext.
alan-white Thu, 03/02/2006 - 06:46
OK....after watching the call viewer in Unity, what is happening is the number 5260 shows up as forwarding to itself, yet when I search through Unity there is nothing that has this number assigned???
Tommer Catlin Thu, 03/02/2006 - 08:56
For whatever reason, your main number is forwarding to Unity automatically. You should go back into CallManager and see where the routing is for this number. If the routing is turned on to forward to the Unity ports, then Unity might get confused and play that message. But if your main number goes to a phone, make sure someone didnt put CallFoward on by mistake and it's somehow in a Unity loop now.
mohamedtag Thu, 03/02/2006 - 12:28
Hello Allan ,
Make sure that there is no CTI Port / CTI Route Point created with the same Extension as the IP Phone Extension. And this CTI Port / CTI Route Point Picks the call and forward it to Unity.
M.Tag
