Warning message
DC Directory Warning in event log
Feb 28th, 2006
  • Silver, 250 points or more
Anyone seen this before and where to start looking? It is occuring every hour on the hour. Where can I find where ServerX is configured at? It appears as if the publisher is trying to make LDAP connection to a non-IPT server in the cluster since the computer name is not one of the CCMs or any other IPT server. I can not ping it by name, etc. There must be something configured somewhere in CCM to cause to reach out hourly.
Event Type: Warning
Event Source: DCDirectory
Event Category: Administrator
Event ID: 7515
Date: 2/7/2006
Time: 1:49:41 PM
User: N/A
Computer: PUBLISHER
Description:
(DSA ASSOC-MGR SEND(43) Proc 29, Sev 14)
Bind failed.
Failed to open association to
/o=cisco.com/cn=DCDSERVER/cn=SERVERX
Association ID = 26
Entity type: Adjacent DSA
Failure reason: Failed to encode BIND request
aman_chugh Tue, 02/28/2006 - 23:11
Publsiher dc directory has replication aggrement with dc directory of all subscriber servers,since this subscriber is no longer in the network you might have remove that aggreement and reconfigure dc directory on publisher server .Check out this link and follow the procedure based on ur callmanager version and dc directory size.
http://www.ciscotaccc.com/voice/showcase?case=K16010016
Aman
