Create 2 new VLANs and Trunk
Answered Question
Mar 1st, 2006
I am working with a service provider to segment inbound traffic for a client. Rather than creating a seperate fibre circuit, we have opted for two new VLANs and a trunk to the upstream router.
The equipment we are working on is a Cisco Catalyst 2900XL, IOS (tm) C2900XL Software (C2900XL-H-M), Version 11.2(8)SA2, RELEASE SOFTWARE (fc1)
Current configuration:
version 11.2
no service pad
no service udp-small-servers
no service tcp-small-servers
hostname
enable secret
ip subnet-zero
ip domain-name
ip name-server
interface VLAN1
ip address
no ip route-cache
interface FastEthernet0/1
speed 10
duplex full
spantree portfast
interface FastEthernet0/2
speed 100
duplex full
spantree portfast
interface FastEthernet0/3
spantree portfast
interface FastEthernet0/4
shutdown
spantree portfast
interface FastEthernet0/5
shutdown
spantree portfast
interface FastEthernet0/6
shutdown
spantree portfast
interface FastEthernet0/7
shutdown
spantree portfast
interface FastEthernet0/8
shutdown
spantree portfast
ip default-gateway
snmp-server community private
snmp-server community public
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
password
login
end
I need to creat VLAN 2 and VLAN 3. Traffic currently running through VLAN 1 will be segmented between these two VLANs with a trunk to an upstream router.
vlan database commands don't appear to be working. At this stage I only want to create the VLANs. Can anyone recommend a command reference?
Correct Answer by pkhatri about 11 years 5 months ago
Ok, just did a quick search. With your release of software, you can only configure VLANs on the Enterprise edition of the software, which yours does not appear to be.
IOS 12.0(5)XU and later support both standard and enterprise edition features.
I suggest that you upgrade if you want to use VLANs.
Hope that helps - pls rate the post if it does.
Paresh
Overall Rating: 4 (4 ratings)
pkhatri Wed, 03/01/2006 - 14:12
  • Purple, 4500 points or more
It's possible that your switch is running as a VTP client which will not allow you to create VLANs. Could you post the output of 'sh vtp status' ?
Paresh
stevenpaterson Wed, 03/01/2006 - 14:18
Hi Paresh!
Good to hear from you!
User Access Verification
Password:
>en
Password:
#sh vtp status
% Invalid input detected at '^' marker.
It doesn't accept the command.
Here are the results of a show ? from enable mode:
publicswitch#sh ?
access-lists
accounting
aliases
arp
boot
buffers
cdp
clock
configuration
controllers
debugging
file
forward
history
hosts
html
interfaces
ip
line
location
logging
mac-address-table
memory
port
privilege
processes
queue
queueing
registry
reload
rhosts
rmon
running-config
sessions
snmp
spantree
stacks
startup-config
subsys
tcp
tech-support
terminal
users
version
glen.grant Wed, 03/01/2006 - 14:19
That is really old code , maybe that is causing your problems . I would try to upgrade if possible . What happens when you try commands within the vlan database ?
stevenpaterson Wed, 03/01/2006 - 14:21
Hi Glen
That was my initial thinking. I can't access the VLAN database.
publicswitch#vlan database
pkhatri Wed, 03/01/2006 - 14:28
It does seem like ancient code... can you post the output of 'sh ver'
Paresh
stevenpaterson Wed, 03/01/2006 - 14:31
c1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Fri 24-Apr-98 10:51 by rheaton
Image text-base: 0x00003000, data-base: 0x001A582C
ROM: Bootstrap program is C2900XL boot loader
publicswitch uptime is 7 weeks, 4 days, 12 hours, 52 minutes
System restarted by reload
Running default software
cisco WS-C2908-XL (PowerPC403GA) processor (revision 0x11) with 4096K/1024K byte
s of memory.
Processor board ID FAA0239U0A3, with hardware revision 0x03
Board ID 0x04
Last reset from warm-reset
8 Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:90:AB:E7:79:40
Configuration register is 0xF
Correct Answer
pkhatri Wed, 03/01/2006 - 14:39
Paresh
