Resource unavailable, call rejected
Mar 2nd, 2006
Problem : as soon as I dial a number,number just vanishes from the phone.
I looked at cisco CDR messages::: DisconnectCause 15 , DisconnectText call rejected (21)
Debug isdn gives::: Resource unavailable..Why?
*Mar 2 12:30:35.838: ISDN Se0/2/1:15 **ERROR**: cdapi_process_connect_resp: cdapi sez to reject the call (appl rejected?)
*Mar 2 12:30:35.838: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9100
Cause i = 0x82AF - Resource unavailable, unspecified
Numbers I was dialing was '8700276161
Note, this happens when call volume is high.the cpu processor util was normal.
Set up is like this
Nortel pbx-->Cisco3845voiceh323gateway-->voip
Thanks in advance
shyam_koneru Thu, 03/02/2006 - 08:56
You might be running out of DSP's. Check the number of PVDM's in the Gateway.
kumarss77 Thu, 03/02/2006 - 10:19
PVDMs we have 256onboard and 60 in Network module. process codec used wazs g729r8.
Jesse Drohen Thu, 03/02/2006 - 12:32
Cause i = 0x82AF
82 - From the public network near the local user (local telco switch).
AF - Resources unavailable, unspecified. The requested channel or service is unavailable
for an unknown reason. This can be a temporary problem.
http://www.cisco.com/warp/public/129/isdn_disc_code.html
What is your IOS version? Is the circuit running clean, any errors on the interface?
kumarss77 Fri, 03/03/2006 - 05:40
IOS version is 12.4 2
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(2)T3,
RELEASE SOFTWARE (fc4)
pri interface looksokay,with small error, 2 interfaces shows 6 error, and 3 crc error, but nothing major.
Voip side circuit was clean throughout the day.
- i feel some kind of performance degradation? only thing i could imagine was dsp farm is not configured.. will it help..?
or any suggestions pls
