Warning message
WEBVPN using Port Forwarding and links
Mar 2nd, 2006
I have a challenge with clients being able to access a web application after the port forwarding is enabled.
The port forwarding is working fine, however when the client clicks on the link (on the concentrators home page)to reach the server the concentrator pre-pends the address and then the application responds to the concentrator not the client.
If a separate window is opened and the port fowarding address url is used it works fine
The web server has an 80 front end but then jumps to 401 for the connection.
I tried having the link launch a new window but if it's launched from the concentrator it still changes the url as if it's making the request directly
Is it possible to have the link work from the concentrator?
y-bielak Tue, 04/04/2006 - 14:34
The port forwarding works fine as long as I launch another explorer window and put in the loopback addresses.
The problem is to setup the concentrator page with a link to execute.
It appears that the concentrator makes the request but the client does not get the reponse.
