WebVPN and Windows Remote Desktop Web Connection
Mar 2nd, 2006
I have setup WebVPN and it's working perfectly except when trying to use Windows Remote Desktop Web Connection through the WebVPN.
I can load the terminal services web page, load the activex and when I click connect an error notification appears saying "Object doesn't support this property or method." Now normally I would associate this with a programming problem, except that this only occurs when viewing through the WebVPN. Has anyone else had this issue? I find it hard to believe that no one else has had this problem, as I can't seem to locate anything about it.
carlos.hernande... Sat, 03/04/2006 - 20:05
I've also struggled with this same issue. I've even created a forwarding rule to allow port 3389 thru, but no luck. I'm very interested in a the solution. If not I'll open a case with Cisco maybe they can figure out what is happening..
Carlos
nysambart Sun, 03/05/2006 - 05:36
I think it has something to do with the way the concentrator is handling the TSWeb ActiveX object. Unfortunately, I can't find out any more than that.
