Warning message
Configuring Cisco 871W as VPN-Server
Mar 2nd, 2006
i've just trying to configure an Cisco 871W as VPN-Server for a couple of clients. The Router is placed behind our default gateway and will have a fix ip.
1. are there any sample configs (IOS 12.3(8)Y3) available to tryout and study ?
2. i need a basic configuration to get ssh-access to the router from the internet. At the moment i try to set the wan-interface as public (with the public ip) and vlan1 as private) -> it dowsn't work propperly yet. :( - are there any standards to follow or is this just the way of choice ?
kind regards, martin
martin.loose Sat, 03/04/2006 - 03:23
thanks für your advice :)
i'm downloading the manuals atm and try them out just when i'm back in the office
jackko Sat, 03/04/2006 - 05:45
  • Gold, 750 points or more
please excuse me for following the entire conversation.
nonetheless, below are the sample codes for remote vpn:
aaa new-model
aaa authentication login vpnauthen local
aaa authorization network vpnauthor local
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group vpngroup
key xxxxxxxx
pool vpnpool
acl 130
crypto ipsec transform-set vpnset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set vpnset
crypto map vpnmap client authentication list vpnauthen
crypto map vpnmap isakmp authorization list vpnauthor
crypto map vpnmap client configuration address respond
crypto map vpnmap 10 ipsec-isakmp dynamic dynmap
interface Ethernet0
ip nat inside
interface Dialer0
ip address
ip nat outside
crypto map vpnmap
ip local pool vpnpool 10.1.1.1 10.1.1.10
ip nat inside source route-map nonat interface Dialer0 overload
access-list 101 deny ip 192.168.1.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 130 permit ip 192.168.1.0 0.0.0.255 10.1.1.0 0.0.0.255
route-map nonat permit 10
match ip address 101
below are the sampel codes for ssh:
hostname router
ip domain-name yourcompany.com
crypto key generate rsa
1024
line vty 0 4
transport input telnet ssh
username cisco password cisco123
aaa new-model
