AP 1200 Radio Interface resets
Mar 3rd, 2006
Hi.
I have problems with a Cisco Aironet Access Point 1200 series (AIR-AP1231G-A-K9). This one presents connectivity problems since it shows resets on Fast Ethernet and radio interfaces. Now, already the physical level of the network is being checked with regard to the Fast Ethernet interface. But why are there resets in the radio interface? What can cause them?
Following the AP information:
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(7)JA1, RELEASE S
OFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 06-Oct-05 09:40 by evmiller
ROM: Bootstrap program is C1200 boot loader
BOOTLDR: C1200 Boot Loader (C1200-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (
fc1)
AP1200_B11Ing uptime is 1 week, 1 day, 20 hours, 39 minutes
System image file is "flash:/c1200-k9w7-mx.123-7.JA1/c1200-k9w7-mx.123-7.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1231G-A-K9 (PowerPC405GP) processor (revision A0) with 14838K/15
36K bytes of memory.
Processor board ID FOC09451RU0
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:15:FA:A4:1E:50
Part Number : 73-8704-10
PCA Assembly Number : 800-23211-11
PCA Revision Number : A0
PCB Serial Number : FOC09451RU0
Top Assembly Part Number : 800-23304-11
Top Assembly Serial Number : FTX0947J04M
Top Revision Number : A0
Product/Model Number : AIR-AP1231G-A-K9
Configuration register is 0xF
Interfaces:
Dot11Radio0 is up, line protocol is up
Hardware is 802.11G Radio, address is 0015.f9a6.5880 (bia 0015.f9a6.5880)
MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,
Last input 00:00:49, output 00:00:00, output hang never
Input queue: 0/75/34772/0 (size/max/drops/flushes); Total output drops: 237
Queueing strategy: fifo
Output queue: 0/30 (size/max)
5 minute output rate 19000 bits/sec, 22 packets/sec
189594 packets input, 24783974 bytes, 0 no buffer
Received 9410 broadcasts, 0 runts, 0 giants, 0 throttles
4095456 packets output, 616703788 bytes, 0 underruns
7709 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
AP1200>
Thanks in advance.
Ramiro Marulanda Z.
I have a few questions to further deal with this issue.
- Is this a new installed AP1200? Is it the first time that customer is trying to connect through
this AP1200?
- Do you have another AP1200 with same software, which is working fine?
- Can you send me a ?show tech? and ?show logg? from the AP1200 with problem?
Also, refer the following document for any help.
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/ap120scg/bkscgc13.htm#10
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
