Configuring 1300 to use External Antenna
rhburns Sat, 03/04/2006 - 18:25
Fortunately for you, I just finished installing a bridge. The answer is 13. Leave off the .5. Hope this helps!!! Another key factor is making sure to include the username and password under EAP Client username and password. It's not optional if using security; which I'm sure your doing. Have a great one!
srosenthal Wed, 03/29/2006 - 11:31
That field is informational only, it has no bearing on the operation of the bridge.
Seth
