wierd vpn probelm
jatinghia
I have setup a cisco 1711 router at my office. I have forwarded 2 ports to a linux box.
ip nat inside source static tcp 10.0.0.107 143 interface FastEthernet0 143
ip nat inside source static tcp 10.0.0.62 22 interface FastEthernet0 22
Every time I connect through vpn from outside, somehow the port forwarding stops working after that and I cannot connect to the above ports. I have to disconnect the vpn and retype the above statments to make it work again.
I have attached my conf file. Since I am newbie any help would be great.
froggy3132000
Level 3
Level 3
If you are coming from the outside via vpn, you should not need the port forwarding anymore. You should allow your VPN pool addresses access to the 10.0.0.0/24 network.
