mheusinger Tue, 03/07/2006 - 02:46
  • Green, 3000 points or more
the task you describe can either be achieved with the help of a TACACS/RADIUS server or by a rather new feature called "Configuration Change Notification and Logging". The detailed description and configuration commands can be found at
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hcf_c/ch35/hconlog.htm
Hope this helps! please rate all posts.
Regards, Martin
