ASDM 5.1(1) syslog display
I've just upgraded a PIX515E from IOS 7.0(1) and ASDM 5.0(1) to IOS 7.1(1) and ASDM 5.1(1).
There's a few minor differences with ASDM 5.1(1) that seem to work weel, but one thing that's annoying me is the way the 'Latest ASDM Syslog Messages' window on the main page does not re-size when you expand the window size. This used to work with 5.0(1) but is annoying in v5.1(1) because you can only see four lines at a time and sometimes you need to see multiple syslog messages are they're scrolling through.
Does anyone know if this is an installation problem, setting issue, or whether this bug will be fixed in a later release of ASDM?
a-vazquez Mon, 03/13/2006 - 06:33
  • Silver, 250 points or more
To me, it does not seem to be an ADSM issue, but windows issue.
h.parsons Wed, 03/15/2006 - 05:16
I noticed the same thing, it makes it useless but they did improve the other logging page.
