VMS IPS IOS Fail Import Sensor
Mar 7th, 2006
I'm using VMS 2.2 with IPS MC 2.1 and I can't add sensor IPS/IOS, router 1841 with IOS Advanced Security.
Look my config to import:
Import sensor configuration
IP Address: X.X.X.X
Group: IOS
Sensor name: rt-cs
Use SSH Keys: true
Port: 443
Use SSH Credentials for SDEE: true
After the connection to router, I've received this message:
Error : Error importing configuration files from the sensor - Unable to get sensor version
Please help me to solve this problem
Cassio Gomes
amritpatek Mon, 03/13/2006 - 07:26
  • Silver, 250 points or more
Check the sensor from CLI if the VMS' ip address is permitted on the access list if not please try to add it:
config t
service Host
networkParams
accessList ipAddress netmask 255.255.255.0
cassio.gomes Mon, 03/13/2006 - 11:48
But this configuration doesn´t work in Cisco Router, only in IDS Appliance. I want to import Cisco Router com IPS enable.
Cassio Gomes
