VoIP Requirement
Mar 7th, 2006
I am trying to setup a VoIP lab and would like to know the specifics of what I need to do that. Also what are the specific requirement for a small startup VoIP carrier/provider. All articles I have read are too general/vague and do not specify any equipment model.
Thanx.
I would greatly appreciate a checklist.
a-vazquez Mon, 03/13/2006 - 12:48
  • Silver, 250 points or more
As per my knowledge the requirements for a Voip networks are.
1.CISCO Router which supports Voice (17xx,26xx,37xx series routers) with voice/wan interface modules having latest IOS which supports IP voice.
2.FXS/FXO/E&M/ ports
3 Wan interface cards(depends on the type of connection with the service provider).
4 Connectivity to TELCO/PBAX.
5 Analog Phones.
6 Wan connection.
alexander.kandelaki Mon, 03/20/2006 - 11:56
You can look into Ebay for cheap hardware for your lab, basically you can get everything on it. But read carefully items descriptions.
You also need to consider for your lab some IP phones, with SIP support. Ethernet switch, i.e. Catalyst 2900 series.
