Warning message
What to command to use to show IP address
Mar 9th, 2006
Gurus, I have a Catalyst 3560, and was wondering what command I could use to show the IP Address of the device plugged into a specific port?
Thanks!
Overall Rating: 5 (2 ratings)
pkhatri Thu, 03/09/2006 - 15:56
  • Purple, 4500 points or more
Hi Mate,
Switches don't collect information on IP addresses plugged into a port. The only thing you can get is the MAC address of the device plugged into the port.
Hope that helps - pls rate the post if it does.
Paresh
glen.grant Thu, 03/09/2006 - 16:03
If you have a switch that is non trunked sometimes you can ping the broadcast address of the subnet and then look in the arp table after you know the mac from looking in the mac-address-table .
