client connection problem
Mar 9th, 2006
I have a VPN set up in office.
Clients are able to connect from remote site (behind another PIX;using private ip addres), but unable to ping or connect to any devices.
client's statistics shows
Encrypted Packets >0
Decrypted Packets =0;
seems like not receiving any vpn packets.
After i configure NAT (on pix) using public to private IP address, the problem was resolved.
like to seek advise on what to do, in order to allow clients w/o additional configuration on other PIXs.
mpalardy Fri, 03/10/2006 - 06:27
  • Bronze, 100 points or more
Doing nat is the right thing to do. Do you also encrypt the interesting traffic?
morgsizun Mon, 03/20/2006 - 05:06
do you see discarded packets in your client's stats?
In this case , il might be a problem with your default gateway.
When the tunnel is up , the default gw must be your VPN Adapater IP adress . Sometimes the default gw stays your lan connection's gw .
A solution is to force your lan connection's metric to 2 to force your VPN Adapter to become your gw.
Morgan Sizun
