leonvd79 Fri, 03/10/2006 - 00:41
  • Silver, 250 points or more
Did you mean "firmware"?
You can show the firmware by issueing the command "show version".
Leon
* Please rate useful posts.
Phoungsakdavin Fri, 03/10/2006 - 00:57
Hi Leon,
I show the verion on the router, but i seem can't find the router firmware's description. Please check the below show verion:
Router#sh version
IOS (tm) 3700 Software (C3725-IPBASE-M), Version 12.3(9b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 18-Aug-04 14:56 by dchih
Image text-base: 0x60008AF4, data-base: 0x61098000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
Router uptime is 1 week, 3 days, 21 hours, 34 minutes
System image file is "flash:c3725-ipbase-mz.123-9b.bin"
cisco 3725 (R7000) processor (revision 0.1) with 248832K/13312K bytes of memory.
Processor board ID JPE084610HE
R7000 CPU at 240MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
19 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of non-volatile configuration memory.
31360K bytes of ATA System CompactFlash (Read/Write)
VIN
leonvd79 Fri, 03/10/2006 - 01:00
12.2(8r)T2 is the firmware version.
12.3(9b) is the current software version.
Leon
