Warning message
CNA and SSH or HTTPS for 2950, 3550
Mar 10th, 2006
I'm using Hummingbird to connect to 2950's and 3550's via an SSH TELNET connection. Is there a way in CNA 3 to do this? I don't see a method but would like to have a secure gui connection to manage port security on switches.
CSCO10662744_2 Fri, 03/10/2006 - 06:54
When you say CNA, do you mean the free Cisco Network Assistant software that allows you to manage multiple network devices through GUI?
I doubt anybody really uses that...I gave it a try just to see what it's like, and the version I used (2.x) couldn't recognize all the modules on my 4506 switch.
I wouldn't use it in a production environment...it may produce unexpected results in the real running-config.
