Warning message
6513 - 6509 Chassis
Mar 10th, 2006
I currently have a 6513 chassis that have the following modules, (WS-6416-GBIC, WS-6316-GE-TX, & WS-6348-RJ45). I'm replacing the 6513 switch with a WS-C6509-E chassis, I need to know if my current modules that are listed above will work in the new C-6509-E chassis? Also what type of module goes into slot-13 of the 6513?
Marvin Rhoads Fri, 03/10/2006 - 10:25
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
The cards you cite are not constrained in the 6509E
Slot 13 in the 6513 is a regular module slot. Some modules only work in slot 9-13, and SFM(s) must be in slots 7 or 8.
Reference chassis installation guide, pages 1-32, -33, and -48: http://www.cisco.com/application/pdf/en/us/guest/products/ps708/c2001/ccmigration_09186a0080231ba4.pdf)
Hope this helps, Please rate helpful posts.
Marvin Rhoads Fri, 03/10/2006 - 10:46
  • Hall of Fame,
Yes.
Support for cards is generally governed more by the associated supervisor card and CatOS / IOS version it is running. Assuming you would be moving that over from the 6513, you should have no problem.
