Warning message
CCM -> CME -> CUE call path troubles.
Answered Question
Mar 10th, 2006
I've successfully intergrated CME and CUE and can make calls both ways between CME and my CCM cluster. However, when I call from CCM to CME and expect voicemail to pick up, my call gets dropped. I can call directly from CCM to CUE, so I know its not a route pattern issue. My dial-peers and telephony-service entries must be correct or I wouldn't be able to access voicemail from my CME phones. I've even tried configuring all possible "voice service voip" allow-connections entries between h323 and sip just in case. Any ideas? Thank you!
CUE version = 2.2
CME version = 3.4
CCM version = 4.1
router = 2621XM "c2600-adventerprisek9-mz.124-4.T1.bin"
Overall Rating: 4.3 (4 ratings)
thisisshanky Fri, 03/10/2006 - 12:11
  • Purple, 4500 points or more
Chris,
You are correct that the problem here is that there are two voip legs (one from CCM to CME) and another (from CME to CUE). One is a h323 leg, while other is a sip leg. To hairpin both legs, you need,
voice service voip
allow-connections h323 to sip
redirect ip2ip
Sankar
PS: please remember to rate posts!
chris.lombardo@... Fri, 03/10/2006 - 14:11
Thank you for your response. I already had the allow-connections h323 to sip in place (I actually had configured all 4 possible options just in case), but did not have the redirect ip2ip line. Unfortunately, this did not solve my problem. My call is still dropped at the point that it should be handed over to voicemail. This was working with my current config when I was running CME 3.3, but after upgrading to 3.4, my problems started.
thisisshanky Fri, 03/10/2006 - 14:45
Chris,
Can you paste ur CME configs ? (passwords, public ips if any masked)
Sankar.
chris.lombardo@... Sat, 03/11/2006 - 19:24
My config (some non-important things removed to get below 4000 chars)
memory-size iomem 10
clock timezone EST -5
clock summer-time EDT recurring
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
ip cef
no ip domain lookup
ip multicast-routing
ip sla responder
ip sla low-memory 2000000
ip rcmd rcp-enable
ip rcmd rsh-enable
ip rcmd remote-host root 10.42.5.50 IWAM_RALDTESTX-XXX enable
ipv6 unicast-routing
voice service voip
redirect ip2ip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
dial-control-mib retain-timer 30
dial-control-mib max-size 400
class-map match-all voip-rtp
match ip rtp 16384 16383
class-map match-all voice
class-map match-all httpc
match protocol http
policy-map queue-voip
class voip-rtp
priority 32
class class-default
fair-queue
policy-map httpp
class httpc
priority 8
police cir 1000000
conform-action transmit
exceed-action drop
class voice
priority 32
interface FastEthernet0/0
ip address 10.42.5.1 255.255.255.0
ip broadcast-address 10.42.5.0
no ip redirects
ip pim dense-mode
duplex auto
speed 10
ipv6 address FEC0:A2A:500::/64 eui-64
ipv6 enable
ipv6 rip 42 enable
service-policy output queue-voip
interface FastEthernet0/1
ip address 10.42.6.254 255.255.255.0
ip broadcast-address 10.42.6.0
ip helper-address 10.43.1.29
no ip redirects
ip pim dense-mode
duplex auto
speed 10
ipv6 address FEC0:A2A:600::/64 eui-64
ipv6 enable
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.42.6.254
interface Service-Engine1/0
ip unnumbered FastEthernet0/1
service-module ip address 10.42.6.1 255.255.255.0
service-module ip default-gateway 10.42.6.254
router rip
redistribute connected
redistribute static
network 10.0.0.0
ip default-gateway 10.42.5.254
ip classless
ip route 0.0.0.0 0.0.0.0 10.42.5.254
ip route 10.42.6.1 255.255.255.255 Service-Engine1/0
ip http server
no ip http secure-server
ip http path flash
ip pim bidir-enable
access-list 110 permit tcp any any eq www
access-list 110 deny ip any any
dialer-list 1 protocol ip permit
snmp-server enable traps tty
snmp-server manager
ipv6 route ::/0 FEC0:A2A:500:0:208:E3FF:FE0B:F5C1
ipv6 router rip 42
control-plane
dial-peer cor custom
dial-peer voice 2999 voip
destination-pattern 2[0-8]..
voice-class codec 1
session target ipv4:10.41.5.30
dial-peer voice 2000 voip
destination-pattern 297.
voice-class codec 1
session protocol sipv2
session target ipv4:10.42.6.1
dtmf-relay sip-notify
no vad
dial-peer voice 9999 voip
destination-pattern 9.T
voice-class codec 1
session target ipv4:10.42.4.254
dial-peer voice 7 voip
destination-pattern 7....
voice-class codec 1
telephony-service
load 7910 P00403020214
load 7960-7940 P00307020200
load ATA ATA030100SCCP040211A
load 7905 CP7905060000SCCP050124A
load 7902 CP7902060000SCCP050124A
load 7971 TERM70.7-0-1-0s
load 7970 TERM70.7-0-1-0s
load 7936 cmterm_7936.3-3-5-0
load 7912 CP7912060000SCCP050124A
max-ephones 25
max-dn 192
ip source-address 10.42.6.254 port 2000
auto assign 1 to 192
time-zone 12
create cnf-files version-stamp 7960 Feb 21 2006 11:17:36
voicemail 2975
max-conferences 4 gain -6
moh music-on-hold.au
web admin system name test password
ephone-dn 1 dual-line
number 2950
name
call-forward busy 2975
call-forward noan 2975 timeout 10
ephone-dn 2
number 2951
name ATA1
call-forward noan 2975 timeout 18
ephone-dn 4
number 2978....
mwi on
ephone-dn 5
number 2979....
mwi off
anup.anand Fri, 03/10/2006 - 22:43
  • Silver, 250 points or more
This could be related to a codec issue as CUE supports only G711. If the call from Callmanager IP Phones use G729, then you would need transcoders.
You might want to check if you have transcoders available in the Callmanager to process these calls.
Anup
chris.lombardo@... Tue, 03/14/2006 - 12:23
Thank you Anup. Unfortunately, I don't believe this is my problem because I can dial directly into CUE via my CCM phone. The only path which causes me issue is going from CCM->CME->CUE.
