Warning message
QoS on the pix placed between the pstn gateway and the Ip Phone
Mar 10th, 2006
Hi, I want to know want QoS rules you apply on the pix located between the ip phone and the pstn gateway.
Thanks for your help !
P.S. Actually some of my user got an "acceptable" voice quality (echo...)
pkhatri Sun, 03/12/2006 - 14:55
  • Purple, 4500 points or more
Version 7.0 of the PIX software supports the Cisco Modular Policy Framework, which you can use to apply policies similar to the way in which you apply QoS policies on cisco routers.
Here's a link no how to configure it:
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a0080450b9a.html
Hope that helps - pls rate the post if it does.
Paresh
