pkhatri Sun, 03/12/2006 - 19:30
  • Purple, 4500 points or more
Hi Norung,
Do you mean the software version ? In that case, simply issue the command 'show version'.
Hope that helps - pls rate the post if it does.
Paresh
012735106 Sun, 03/12/2006 - 20:04
I show version but i can't see firmware version on the pix 515e.
How can i do?
Any reply is appreciated.
Norung
pkhatri Sun, 03/12/2006 - 20:09
Is there a particular component on the PIX that you want the firmware version of ? The PIX runs software, not firmware, and that is what you see with 'show version'
Paresh
012735106 Sun, 03/12/2006 - 21:05
Hello Paresh,
The below pix's show version 6.2(2) is the pix's OS version,but i need to know its firmware version.
pixfirewall# sh version
Cisco PIX Firewall Version 6.2(2)
Cisco PIX Device Manager Version 2.1(1)
Compiled on Fri 07-Jun-02 17:49 by morlee
pixfirewall up 82 days 19 hours
Hardware: PIX-515E, 32 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 000b.bed3.7e75, irq 10
1: ethernet1: address is 000b.bed3.7e76, irq 11
2: ethernet2: address is 0002.b3d9.f100, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES: Enabled
Maximum Interfaces: 3
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
Serial Number: 807020507 (0x301a27db)
Running Activation Key: 0x56ac8799 0xff4cdd22 0x7f05220e 0xad83e5c9
Configuration last modified by enable_15 at 10:09:26.933 UTC Mon Mar 13 2006
pixfirewall#
Norung
jackko Sun, 03/12/2006 - 21:52
  • Gold, 750 points or more
please excuse me for not following the entire conversation.
i was just wondering what you are referring to as a firmware. i usually use the term pix os and pix firmware referring to the same thing. so v6.2(2) would the answer you are looking for.
012735106 Sun, 03/12/2006 - 22:51
Hi Jackko,
Thanks for your reply. But I still wondering that why the Cisco router's IOS and Firmware software are different and Pix's OS
and Firmware are the same.
Norung
