pkhatri Sun, 03/12/2006 - 21:36
  • Purple, 4500 points or more
Hi Mate,
When you configure SVI (Switch virtual interfaces) on a L3 switch, the switch will treat each subnet configured on the SVIs as a connected interface. Therefore, it know where each of the connected networks resides. It does not, therefore, need a routing protocol to route between these subnets.
If you have a more complicated network, with multiple routers, a layer 3 switch that does inter-vlan routing will need to use a routing protocol to exchange routes with the routers. But in a simple network, you can get away with just using a switch/router for inter-vlan routing without running any routing protocols.
Hope that helps - pls rate the post if it does.
Paresh
balajitvk Sun, 03/12/2006 - 21:42
  • Silver, 250 points or more
Network devices in different VLANs cannot communicate with one another without a router/L3 Switch to route traffic between the VLANs.
Just go thro, this link to understand the concept with some configuration examples,
http://www.cisco.com/en/US/products/hw/switches/ps679/products_configuration_guide_chapter09186a008007d1b7.html#xtocid30231
Rgs,
Balaji
pkhatri Sun, 03/12/2006 - 21:50
With a L3 switch, you would have config such as the following:
interface VLAN10
description SVI for VLAN 10
ip address 10.1.1.1 255.255.255.0
interface VLAN20
description SVI for VLAN 20
ip address 10.2.1.1 255.255.255.0
The above will result in two directly connected routes being installed in the routing table:
10.1.1.0/24
10.2.1.0/26
Therefore, the switch will be able to route between nodes belonging to the above two subnets.
Paresh
balajitvk Sun, 03/12/2006 - 22:04
As a addition to Paresh, if u have router instead of L3 Switch,
create a subinterface in router where the uplink from the switch is connected,
In a switch,
interface FastEthernet0/1
description connectivity to router
switchport trunk allowed vlan 2000,1000
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 2000
switchport mode access
interface FastEthernet0/3
switchport access vlan 1000
In a Router,
interface FastEthernet0/0
description *** TO Switch *****
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1000
description Connectivity to 1000 vlan thro. switch
encapsulation dot1Q 1000
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0/0.2000
description Connected to 2000 vlan thro. switch.
encapsulation dot1Q 2000
ip address 20.20.20.1 255.255.255.0
Rgs,
