CiscoWorks shadow directory
Mar 13th, 2006
I have selected "shadow directory" option after several days CW running. After selection only devices with changed configuration appears in the directory structure. What is the easiest way how to force CW to save configurations of all devices to shadow directory?
Thanks in advance.
nhabib Mon, 03/13/2006 - 12:28
  • Red, 2250 points or more
Unfortunately there is no easy way to do this. You can modify the config of each device, or re-init the RME database.
puk Tue, 03/14/2006 - 11:47
I guessed that.
Thanks.
