Recommendations about the best way to bond 2 T1's
Mar 13th, 2006
Considering redundancy, getting as much bandwidth as possible and future QoS support, what is the best way to bond two T1's? I am currently running multilink because in the lab it behaved the way I wanted. I have two identical sites, one works fine and the other bounces up and down as soon as I introduce traffic. I only have one T1 plugged in until I can get the second installed. If I change my clock source from line to internal it goes down and stays down. The TAC says that I need the two T1's or the clocking will be messed up. If that is true then I do not have redundancy.
Overall Rating: 5 (1 ratings)
spremkumar Mon, 03/13/2006 - 05:55
  • Red, 2250 points or more
hi
i feel some clarification is required here inline with the connectivity you have in place.
Is the central(HO) lcoation connected to 2 identical sites ? or connected directly to one location ?
regds
spremkumar Mon, 03/13/2006 - 06:09
hi
regds
mike.cunningham Mon, 03/13/2006 - 06:50
Yes the central location is connected to two identical sites, It will be two T1's each eventually but one for now.
matthew.mcbride Mon, 03/13/2006 - 09:52
Mike,
I too, have two bundled T1 circuits on a point-2-point network with MLP enabled. Things work just fine in the event one of the T1 circuits goes down. One trick in our scenario with the clocking is, since we have a point-2-point environment, the carrier is not providing the clocking so one router on one end of the bundle is providing clocking.
Here is a sample config:
RouterA:
interface Multilink1
description mu1:T1_Bundle
ip address 10.99.0.2 255.255.255.252
ip access-group 2001 in
no ip redirects
no ip unreachables
no ip proxy-arp
fair-queue 1024 256 64
ppp multilink
ppp multilink interleave
multilink-group 1
interface Serial0/0
description s0/0:T1_Circuit_ID
no ip address
encapsulation ppp
ip route-cache flow
no fair-queue
ppp multilink
multilink-group 1
interface Serial0/1
description s0/1:T1_Circuit_ID
no ip address
encapsulation ppp
ip route-cache flow
no fair-queue
ppp multilink
multilink-group 1
RouterB:
ip address 10.99.0.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ppp multilink
multilink-group 1
interface Serial0/0
no ip address
encapsulation ppp
ip route-cache flow
no fair-queue
service-module t1 clock source internal
ppp multilink
multilink-group 1
interface Serial0/1
no ip address
encapsulation ppp
ip route-cache flow
no fair-queue
ppp multilink
multilink-group 1
As you can see from the config, RouterB is providing the clocking for both T1 circuits. If one T1 fails, the remaining circuit in the bundle carries the load.
Hope this helps.
-m2
mike.cunningham Mon, 03/13/2006 - 10:17
This config is almost the same as mine except that if I enable internal clocking on either end the circuit comes down and stays down,
