Warning message
connecting to multiple sites from central isdn router
Mar 13th, 2006
Hi there, I have 8 remote sites and one central, I am using chap on all of them, on the central router do I have 2 bri ports, so I have 2 pools with 4 branches in each pool, what do I need to put on the central router for usernames and passwords, do I just type username and password of each router in the global config, or does this need to be done in each dialler interface ie ppp chap hostname remote1 password test ?
is this correct ?
spremkumar Mon, 03/13/2006 - 05:45
  • Red, 2250 points or more
hi
You can configure the username and password in the global config mode and just simple "ppp authentication chap" uunder the dialer interfces.
regds
carl_townshend Mon, 03/13/2006 - 15:40
could I not just use ppp authentication chap, ppp hostname test password test on the dialler interface, or would it use the username and password from the global config mode ?
